automating record process
Unread post by nay-seven » 18 Feb 2007, 10:48
in automation , i mean when you choose to record only for example track 2 in the record window, could be usefull to stop the play for other tracks ( low cpu and no click with my little celeron 3000 ;-) , i know i can do it manually but you know ...musicians are lazy boys
just an idea...
Unread post by senso » 18 Feb 2007, 11:37
'stop the play' do you mean 'mute'?
Unread post by nay-seven » 18 Feb 2007, 11:50
no , i mean stop the play of the tracks unused , cause the mute function don't reduce cpu usage..stop the play , yes
