select midi port on midi in modul
joffo78
Unread post by joffo78 » 23 Nov 2010, 10:01
Hi
It would be nice if we could select which midi port to listen on each midi in modul on one track.
For the moment when i create a track with a midi in modul i can on the head of the track select the port taht i want to listen
(the blue squares) But i can't filter there.
the idea is to can select in the midi input box as the chanel filter between all port or only one of the activated ports.
ethnix73
Unread post by ethnix73 » 23 Nov 2010, 10:22
You can do like this joffo78:
Seb.Dub
joffo78
Unread post by joffo78 » 23 Nov 2010, 13:31
great thank you !
Unread post by bsork » 23 Nov 2010, 13:44
You should however check whether this works ok if and when you send data simultaniously to more than one Midi input.
Users browsing this forum: No registered users and 40 guests
