Key & Midi Learn modes?
Clearscreen
Unread post by Clearscreen » 02 Mar 2010, 10:17
Would it be possible to split the mode (absolute/relative/toggle) of the key & midi learns? I've got F1, F2 etc keys set to track mute which needs to be a toggle, but when I assign my midi controller they need to be absolute to properly...
I've tried every possible combination of settings in my midi controller but to have the correct feedback state on the midi buttons the midi learn has to be on 'absolute', which means I then give up being able to use me F1, F2... keys - any solution Senso?
Unread post by nay-seven » 02 Mar 2010, 10:28
maybe don't understand your problem but each midi or key learn can have a different mode..?
you can have 1 switch in toggle mode , one in absolute..?
Clearscreen
Unread post by Clearscreen » 02 Mar 2010, 23:59
Really? As far as I can see in the remote panel I've got the 'F1' key and midi 'CC10' both assigned to the track 1 mute button, but there's only a single drop down for 'mode' - am I missing something?
Unread post by nay-seven » 03 Mar 2010, 00:24
ho, ok !
so , if you really need this , you can make a patch with some mixer track output modules( 1 by track )
link 2 switch ( group 1 ) to the M inlet , one with a key learn , one with a midi learn..
and different mode..
Clearscreen
Unread post by Clearscreen » 03 Mar 2010, 04:06
Nice workaround Nay, but it'd be easier and quicker if it was in the remote panel...
Unread post by senso » 06 Mar 2010, 10:15
let me think about this.
