The Echoplexx improvement ??
noise2sine
Unread post by noise2sine » 07 Dec 2009, 16:08
I'm a great fan of the echoplexx but i think that the saving process is not really easy.
I'm giving an example for explaining my request :The base is recorded and then i record the four layers left. My request consist of just one button able to save the base and the four layers in the different samplers at the same time ?
i have another question : which is the best way for recalling the different base recorded with all the different layers with just one click ? preset manager can do the job ?
In case i want to use the conductor ihave to use a list box from file inlet of the sampler. Is it possible that the list box module can be automaticly updated with new sample recorded in the the sampler list ?
manecante
Unread post by manecante » 07 Dec 2009, 18:40
"Is it possible that the list box module can be automaticly updated with new sample recorded in the the sampler list ?"
i would also find it usefull.
Unread post by senso » 08 Dec 2009, 10:13
create an inlet,connected to 'sampler/save rand' in all layer sub-patch. Then connect them in a single 'save' button.
the preset will do the job
the V5 will provide an efficient way to manage samples list.
noise2sine
Unread post by noise2sine » 08 Dec 2009, 11:05
Super ! xmas 2009 will be great !
thanks again Senso for yr answers !
Have a nice musical day !
