One thing that I have trouble with in Usine is that when I add new modules to a patch that already has multiple preset/conductor saves, I have to go to each preset/conductor and store the new items at the default value otherwise the last set value in a new preset will be the default value in all the other presets. It would be great if the current values of a module could be stored into all preset and conductor slots simultaniously. This would make it much easier to add upgrades an existing patch that uses many presets.
Of course I realize that this suggestion is probably not an easy one to add to Usine...
add current/default value to all presets
I'd second this!
- senso
yes I know that in some situations it can be tricky.
I'll think about a solution.
