Range fader
lalo
Unread post by lalo » 18 Oct 2006, 00:01
hi,
the current range fader is a bit unconfortable..if you link 2 faders to the range fader to automate start and end of the range via midi..you'll not be able to move the range fader on the usine patch itself...
at present time range fader can't be directly "midi-learned"..would be nice if it could be
thanx
Unread post by senso » 18 Oct 2006, 12:41
hello,
you are very active and it helps me a lot to improve Usine!
I know that the range fader is "uncomfortable".
Actually, It's impossible to make a midi learn on It.
If fact the best thing should be to have a midi learn on the left side, right side, and both.
It's hard with the actual Usine structure. (only simple midi learn are allowed).
For me, the best way is to create a sub patch with 'has changed' and 'stop event flow' modules to allow simple learn (on faders, as you do actually) and allows modifications in the range module itself.
I'll try to make an example and post it in the add-ons.
Unread post by bsork » 18 Oct 2006, 16:10
Hello!
Would it be possible to "unlock" (or what I should call it) the input of the interface design modules? In fact, for two faders you're almost there already: I tried to hook up two faders in a "loop" out1>in2, out2>1, and when moving fader 1, fader2 followed as expected, but not the other way around.
(And yes, I know the example is pretty far-fetched and useless...)
Unread post by senso » 18 Oct 2006, 17:12
interesting conceptual problem!
fader1 out --> fader 2 in ---> fader1 in
if Usine was conceptually perfect, you shouldn't able to move any fader: fader 1 is master and slave of the fader 2.
It's an unless loop.
Fortunately, Usine is not perfect (you know that!) and the endless loop is broken. The patch, in that case, is calculated in a precise order: the older (the first created fader) is calculated first and the older is calculated after (the second fader).
They is a solution to your problem: use 'has changed" and "stop event flow" modules to break the endless loop. I do it often. Stop event flow means "the wire is deleted" in Usine language.
I've discovered a small bug: in your example, you can change the second fader position, but is has no effect: only the fader display changes but not the real value. Bug fixed now.
lalo
Unread post by lalo » 28 Dec 2006, 15:26
senso wrote:I'll try to make an example and post it in the add-ons.
hi senso, did you try some solution?..
the event scheme of usine is not so clear to me :)
Unread post by senso » 29 Dec 2006, 08:16
Sorry I forgot!!!!
I will do it soon...
Unread post by senso » 29 Dec 2006, 08:32
done...
You can see an example in the add-ons.
lalo
Unread post by lalo » 06 Jan 2007, 12:07
thanx for the example senso :)
but it doesn't work like i expected....
i mean it work with external midi learned controllers...but the range fader doesn't send any value if moved directly with the mouse...
wich is what i'm trying to achieve ..as with other ui controllers...they work both mid-learned and on the gui
thanx
Unread post by senso » 06 Jan 2007, 13:59
I'll check it
lalo
Unread post by lalo » 06 Jan 2007, 14:08
thanx
Unread post by senso » 11 Jan 2007, 10:45
I've just created some new modules to allow the construction of such patch very easilly:
'pass only if it as changed' module
It will help you.
next release
lalo
Unread post by lalo » 11 Jan 2007, 10:49
hi senso,
thanx!
what i wonder about is that the patch works with a pair of faders but does not with a rang fader....
thanx
ps...a little language bug :)
"as" should be "has" i guess..
