I've tried to send one buss to several destinations, and this doesn't work.
It would make the patching SO much cleaner if it did!
It would also be nice to be able to mix several sources into one destination. It's more complicated, but usine already does it with regular patching, so I'd think it would be fairly easy.
cheers!
-eric
multiple buss destinations (and sources?)
Hi, what kind of data are sending through the busses? I just did a check of my old PunchInLoops workspace which uses arrays through busses to distribute data from a master patch to the various other patches, and that works fine. Admittedly, there is not much data passing, mostly a 0 or 1 once in a while.
hmmm. I was trying to mix audio, now that I think about it.
maybe distributing data will go better!
