Extended template functions.
Unread post by bsork » 03 Nov 2008, 21:56
I would like to see some extensions to the templates - not to the template files, but a way of organising templates so that if more than one option is possible (like with the current dialog box asking for normal or grain sampler), one can pick which one to use from a list. The categories could be like it is now, I guess.
Unread post by senso » 04 Nov 2008, 14:02
yes It's a good suggestion.
I need a deep refection about the template management in order to simplify the patching process...
