list and combo graphics in touchscreen
Unread post by woodslanding » 28 Oct 2008, 18:16
A couple of tiny notes:
When a combo is displayed as a slider, there is a BIG square box that is just wasted space and does nothing. But on a list, there is a MUCH SMALLER box that needs to be used to scroll the slider. It's hard to get a hold of!
It would be more helpful if it was the other way around....
Just a thought.
-e
Unread post by senso » 28 Oct 2008, 20:37
As I can remember we have discussed before about combo-box behavior in touch screen environment.
But, in the next version you will be able to customize the combobox layout as you want!
Unread post by woodslanding » 29 Oct 2008, 06:44
Great! I will wait and see.... and try hard to be patient! :)
