Hello Senso,
I am trying to synchronize Usine to a MTC code coming from Protools.
Everything works fine until I stop PT to program something in Usine, because when the MTC flow stops, usine stops to. So I used the "Dashboard continue" to work in Usine while PT is stopped but if i stop PT (for exemple) to listen to an end of reverb or delai, Usine stops and the sound is cut before i press "Dashboard continue".
To my opinion, the time code and the dashboard Play/stop should be more separated. The time code should be able to run while usine is stopped and usine should be able to play while time code is not running.
MTC is too fragile to be the master of the dashboard Play/stop.
"Dashboard continue" could be a more general button, an option you choose in the Setup, that alows you to always leave the dashboard running even if Usine loose MTC.
Thanks for your help
Golivesi
Usine Stops when I stop Protools while they are sync via MTC
www.gillesolivesi.com
Shuttle with AMD Atlon 64 4000+, Apple MacBookPro
Apple MacPro, 4x UAD-1 DSP cards, RME FF400
FF800 & Hammerfall, Protools LE and USINE
I'll think about that.
Normally it should possible to stop the smpte and let the sound still playing...
