osc in global interface control
Clearscreen
how do you mean? like an 'OSC learn' similar to 'midi/key learn'?
no...
i mean just a field in wich insert the osc command that control the particular parameter
in " inputs/outputs" you have a new module named " send midi to usine"
so you can build a patch that send osc to midi to any parameters of Usine , as the mixer ones...
Can't you use the OSC receive module with the module "mixer input" and "mixer output"?
Seb.Dub
yes...but in this way i have to do it for every patch loaded in the track slots....ethnix73 wrote:Can't you use the OSC receive module with the module "mixer input" and "mixer output"?
i'd like to have a thing that is valid for every patch loaded in the track in every slot
You could create sort of a "master" patch that's always active - where the patch resides doesn't matter. You could for instance put it into one of the master in-/output patch slots.
I'm not sure I understand your pb.
personally I use the bsork solution:
a kind of OSC master patch which distribute osc values via data buses.
Users browsing this forum: No registered users and 74 guests
