Sending All note Off before switch off Usine
cybercharles
Unread post by cybercharles » 12 Feb 2009, 11:30
Hi
a simple suggestion to implement in USINE :
Send all notes off before switch OFF Usine.
Because actually when you switch OFF Usine and MIDI data are sent to external machines the notes stay ON. I'm oblige to stop Usine when is not reading a MIDI note.
Charles
t
Unread post by nay-seven » 12 Feb 2009, 12:52
what about this :
global midi and key learn ( ctrl F4 ) : assign space bar( or whatever else ) to dashboard stop and to dashboard Panic...?
cybercharles
Unread post by cybercharles » 12 Feb 2009, 17:22
Hi
as usual USINE can do everything !
I will try this solution to night and give you the feedback.
Charles
t
cybercharles
Unread post by cybercharles » 13 Feb 2009, 12:36
It works !
that all
see you
t
Unread post by senso » 13 Feb 2009, 15:48
good tip also for me!
Users browsing this forum: No registered users and 27 guests
