loop recorder sequencer
franck
Unread post by franck » 12 Jan 2009, 12:32
Hello Olivier and Usiners,
I use the Antwan patch add_ons "Sequencer continous loop recorder" in other section add-ons (thank again Antwan)
I have two problems
I use it to reccod audio files between 2 loop markers, each loop create an audio file with the same lenght of my two loops
markers.
I must to make a "continous loop recoder" smaller than my two loops markers (the begin of the patch must begin just a litle
after the begin loop marker) If I want the patch record an audio file. And it is a problem because recoded files are not exactly the same lenght than my loop markers, to small ...... Any solutions ?
My second problem is when a loop is recorded (each time the loop is finished to read, an audio file is created on disk) there is some audio noises when my loop is playing again, it is difficult to play in synchronization ......
Not a possibility to keeps all records in RAM until I stop rec, and after write alls files recorded ?
I precise I dont want Usine plays what Im recording, I import thoses recorded audio files after in Usine.
Franck et ses amis
Unread post by senso » 13 Jan 2009, 11:47
interesting suggestions
I'll think about all of that and try to find a solution
franck
Unread post by franck » 13 Jan 2009, 14:08
Hello Olivier,
We are Happy Happy.....
Very nice New
thanks
franck et ses amis
Unread post by senso » 13 Jan 2009, 19:02
But not soon.
I need time
comemo
Unread post by comemo » 17 Jan 2009, 14:48
cool !
