"num virtual" option to Midi Learns?
antwan
Unread post by antwan » 19 Aug 2008, 18:47
As I do a midi learn I sometimes find myself yearning for a possiblity to specify the num virtual of the device.
I.e. if I have two midi in devices, both sending on midi ch 1, sending the same CC numbers etc. it could be great to have the option to specify the num virtual so that the two devices don't control the same things.
Anyone feel this might be a worthy addition?
antwan
Unread post by senso » 20 Aug 2008, 17:38
it's a good suggestion.
I'll try to put it in my 'TODO' list. Unfortunately it will be hard in the next release.
