Workspace Mute
hgermain
Workspace Mute
Unread post by hgermain » 14 Feb 2025, 12:30
i'd like to be able to mute each of the two workspace that can be opened in the same time.
i mean the whole workspace,
because in my workflow, i usually load an empty wkp for the new project,
and load "in the background" another workspace full of sounds, racks, etc, in witch i take what i need for the new project.
i dont't know how other use kp 1 & 2,
for me it would be very usefull not to have to worry about sound coming from the other wkp, be able to mute the whole wkp.
a sort of solo near the 1/2 button,
better would be a play button near each ?
i've tried to do it with no success. maybe someone have a workaround ?(out of using rack solos, witch can become a real mess when you got a lot of racks in two wkp !)
btw, the racks loose there name in the copy/paste process from a wkp to another. would it be possible that the name follow ?
thanks & best
Hughes
Unread post by senso » 24 Apr 2025, 12:08
We can't find the proper ergonomic solution for this suggestion. Except adding another dangerous "mute" button in the already "dense" GUI
fixed in the new major release
Unread post by SylvainT » 25 Apr 2025, 09:23
Hello Hughes,
Why don't you just deactivate all the racks in your second workspace ?
You can easily create a small patch with the rack settings module, in a polyphony, with a constant=0 or a switch wired on the ON inlet and poly voice number wired on num rack. All your racks will be OFF by default. It will act as a master mute for your second workspace.
If you copy a rack and paste it into your other worspace, it will be ON automatically.
Best
workspace 2 mute.pat
(24.68 KiB) Downloaded 434 times
hgermain
Unread post by hgermain » 13 May 2025, 20:29
Thanks Sylvain, a good way to easily manage the On/Off of more than a hundred racks !
i had never used polyphony (Usine can always remember you that you still have a lot to learn ;-)
So after a Tuto time, it works ! great !
best Hughes
