Mani volume out object
lalo
Unread post by lalo » 29 Jun 2006, 15:40
Hi olivier,
we already have the "mix" object wich we can use to deal with tracks' parameters...
i'd really like to have a "main out" object...
i'm trying to control the main out with a midi pedal...
but i'd like to limit its min and max limits..an to invert the 0..127 scale...
my damn pedal sends inverted scale :)
thanx
Unread post by senso » 29 Jun 2006, 16:36
It's very easy to create a main volume module.
I hope in the next version.
Unread post by bsork » 30 Jun 2006, 09:12
About the pedal: if the controller thing that you have connected it to, have some sort of pedal calibration - and many (or most?) do - maybe it's been configured the wrong way around?
Given the clumsy and unintuitive methods and messages that some controllers use when doing what should have been really simple stuff, it's often easy to get something wrong. Well - at least I've been confused by things like this from time to time...
Unread post by senso » 03 Jul 2006, 19:24
the main volume is implemented in the next release
