Reading the manual it looks like this should be in the master panel, but it doesn't seem to be.
Rename wkp would also work for my purposes.
Okay, as usual, asking the question provides the answer. I think I can have a button that runs a script that:
1.saves the wkp (always called autoload)
2.copies it
3.renames the new wkp file (something referring to changes...)
4. Moves the file to a history folder.
Then I always have an autoload wkp, but I also have a folder of old wkps with a history of changes in case I need to revert.
I'll leave this here, in case it would help someone else.
-e
save wkp as
save wkp as
I guess I should move this to patching forum, sorry.
This can work, except that I'm not sure how to know when the wkp is done saving.... is there a way to know this?
I guess for now, I can have a 'backup wkp' feature that just copies, renames and moves Autoload.
Using a file lister with a clock on refresh (directed to your history folder). Has changed on the commatext output.
When your file is saved, your history folder gets a new file, so the commatext output of the file lister has changed.
Or dierctly directed to your save folder.
Users browsing this forum: No registered users and 81 guests
