I want to record sound, edit the length and save to a file
I know I can do that by patching a 2nd sampler recorder and have the 1st one played into the 2nd one while re-recording, but it take time
for example : I record a sound with a sampler, then I select the part I want with "start" and "end", then I would like to only have what is between those limit to be saved to a file (instead of the whole recording)
sampler : save file between start and end
Yes, good idea! That's a function (export selected) that is missing
