PDF Player ?
PDF Player ?
Unread post by rlgsbt » 12 Jun 2024, 13:57
Hello Senso,
I'm still one of those old musicians who sometimes need to read sheet music at the same time as playing their patches and workspaces... Is it possible to insert a PDF reader? Or to output PDFs via the video out?
thanks
Unread post by senso » 21 Jun 2024, 18:47
maybe you can transform you pdf into bitmap or jpg and import it in Usine?
Unread post by oli_lab » 23 Jun 2024, 20:55
or use Usine to open a web page with th pdf
Unread post by rlgsbt » 23 Jun 2024, 23:56
oli_lab wrote:
23 Jun 2024, 20:55
Great idea.
Unread post by rlgsbt » 24 Jun 2024, 08:01
the "Web Browser module" open the default PDF Player (so you can't manage it in Usine). The good solution would be the new "Panel Embedded Web Page" witch also display the pdf directly in Usine. This module display all the needed options BUT you loose the display in IB mode (it's reaching a webpage). You have to click on the URL again.
@Senso, is it possible to force the URL ? a kind of "affect" especially for string ?
thanks
Unread post by senso » 30 Jul 2024, 18:56
@rlgsbt Sorry but I'm not sure to understand by
Can you explain ?
Thanks+++
Unread post by rlgsbt » 01 Aug 2024, 08:17
The "Panel Embedded Web Page" module display the pdf BUT you loose it in IB mode (it's reaching a webpage) or each time you change the view. You have to click on the URL again in the "Panel Embedded Web Page" module .
May be you could add a fonction to "affect" the url string in to force the module to display again the pdf file ?
Here is a simple patch which doen't work, but will give you an idea of my problem.
Thanks Senso
expdf.wkp
(106.24 KiB) Downloaded 535 times
Users browsing this forum: No registered users and 99 guests
