Mixeur
Mixeur
Unread post by Gilsornette » 26 Mar 2024, 18:14
It could be useful if the Mixeur (and so the faders in it) has a resizable option.
And also an option "show only active racks".
Thank you
joffo78
Unread post by joffo78 » 27 Mar 2024, 11:29
Hello gilles.
I think it's easy to make your own
joffo78
Unread post by joffo78 » 27 Mar 2024, 11:40
Here's a quick example.
My only problem is that I can't keep the order of the faders straight.
To achieve this example I used a new concept present in usine 6. the additionnal container.
mixer auto.wkp
(297.62 KiB) Downloaded 369 times
Unread post by Gilsornette » 27 Mar 2024, 14:32
Hello Joffo,
Thank you for your help. But it's not so efficient than the Mixeur implemented in Usine; with it you just have to drag and drop your racks and gain faders appear with also
mute , solo, on/off rack. In a very easy way. I just miss a resizable option, as almost all objects have in Usine.
Users browsing this forum: No registered users and 110 guests
