UltraLeap Gemini
UltraLeap Gemini
Unread post by oli_lab » 07 Jan 2023, 20:27
Just received the UltraLeap 3DI camera and installed the latest software (Gemini 5) but the leap motion module is not compatible with this new piece of software (yet).
the V5 is much more efficient and fast than previous versions, that it can make the ultraleap an interface of choice.
what is the solution !?
gercha1
Unread post by gercha1 » 02 Feb 2023, 20:11
what version of software would you use for the leap ? I have a problem with version 2.3.1 which worked very well before on other pc but that I no longer work on a new pc
Unread post by rlgsbt » 02 Feb 2023, 22:41
I've got the same problem. This version does not work anymore on my pc. A problem with my graphic drivers....
