Select rack with midi or OSC
JF
Unread post by JF » 09 Aug 2020, 23:04
I hope it's not already done .. It would be really useful to select a rack with midi ou osc command.
I use "active mode" "if rack is selected" and when I use a midi pedal I don't so easy access to my computer to use the arrow left and right.
Thanks a lot.
Unread post by SylvainT » 10 Aug 2020, 14:37
You can find an inlet on the "Usine Workspace Settings" module, "visible racks".
All the best
JF
Unread post by JF » 10 Aug 2020, 18:16
Hello Sylvain,
Thanks for your answer.
I think the inlet "visible rack" is for making the rack visible but not selected.
And if the rack is not selected and you use "if rack is selected" with midi , it doesn't work. That's why I'm looking for a way to select racks without keybord Or I misunderstood something ?
Unread post by SylvainT » 10 Aug 2020, 18:47
Ok, sorry, I read to quick and doesn't give you the right answer.
For sure we have this option on patches, as I asked for that years ago, "select control panel" inlet on "usine patch settings" module.
But not on the "usine rack settings" module. Could be usefull.
Developement team is on holidays for now. I think it's not a big deal. Wait for next major release.
All the best
JF
Unread post by JF » 10 Aug 2020, 19:56
It's exactly what I need ! Select patch is perfect too !
Thanks !!
Unread post by senso » 24 Aug 2020, 12:31
hi,
will be implemented in the next release
- [usine] new select-rack-panel inlet in usine-rack-settings module
- [usine] new minimize/maximize inlets in usine-rack-settings module
