I just checked out HH4. Disappointed there is no z-index on the modules, still just "on top" (with a new backwards option).
This should be in with the mouse/touch stuff, although currently no touchscreen can "pull" things up or "push" them down.
If you set 2 things as "on top" either one can actually end up on top.
Many times I want to control more than 2 layers.
Simon.
z index instead of just "on top"
Yes, I agree, sometimes I need more than 3 positions for layers.
But, I think it will be a problem for compatibility for all user if Senso changes something there.
Let's see.
Let's see.
it was discussed before and the problem was that if you're given ability to input specific Z index, it can easily clash with same index. but, I think as a secondary setting this could work out easily, like if 2 same Z-indexes meet, then follow current layering priority system and that's it. I think this will not break compatibility at least (not like there's forward compatibility).
It's an hard job to do that especially in a cross-platform context.
Actually, the z-order is the object creation order. so after a ctrl-X and and ctrl-V the z-order is automatically set "on top". So you can change manualy the z order in special cases.
