Hi Olivier,
A few suggestions:
- in the piano roll the possibility to set the grid to triplets (or other nuplets), when entering notes with the mouse (maybe a fader "grid" we could set to 2, 3, 4, n, that would set the basic grid, an then as it is now the precision of the grid depending of the zoom factor).
- in the step or line modules the possibility like in faders to set the precision (integer ; ,x ; ,xx ; etc...). I've tried some workaround: step "values" out -> math "round" -> pass if changed -> step "values" in, but it doesn't work quite well.
- maybe also in the step and lines, the possibility to display a vertical grid (I mean display n horizontal lines as a guide to set values)
- in the "listbox buttons" (and maybe also other listbox modules) the possibility to set quantization.
What do you think?
Regards,
B.
Few suggestions:
good suggestion, I'll try to implement them soon.
I'm still busy with the vst debug.....
Im agree with bmoussay, but not only for the piano roll module, for the piano roll sequencer too.
good work Olivier
franck
good work Olivier
franck
in intern both (module and sequencer) are the same, so don't worry!
Users browsing this forum: No registered users and 64 guests
