FASTER PRESET MANAGER
Ariajazz
Unread post by Ariajazz » 19 Dec 2018, 04:57
It currently takes around 1 second (sometimes even more) to recall a stored preset. It would be great if it could be as fast as the old CONDUCTOR module from v5.
x.iso
Unread post by x.iso » 19 Dec 2018, 12:00
+1
maybe an option to keep presets in RAM? if they aren't already.
Unread post by sm_jamieson » 19 Dec 2018, 15:38
Would be nice if you could use presets like you can in something like Mainstage, in an actual performance (must not interrupt sound). I used a custom method in a user module since all I am doing is sending midi program changes and the odd control of a patch "bypass", etc.
The way it must be done in something like Mainstage is that all presets used in the Concert are cached or pre-loaded in RAM, plugins ready, etc. On the other hand Mainstage has a habit of loading lots of instances of plugins and I like controlling this a bit more.
Users browsing this forum: No registered users and 74 guests
