change query index without re-dropping the module
Unread post by sm_jamieson » 11 Jun 2018, 19:57
It would be useful to have a way to change or cancel the query index (value chosen in the query menu) for any modules that uses it (User Modules, but also other modules where the user chooses the number of faders, etc.).
Currently you have to delete and re-drop the modules (or edit the Usine config files).
Unread post by SylvainT » 13 Jun 2018, 01:23
Try to reload the module
All the best
Unread post by senso » 01 Nov 2018, 12:19
actually you can use the command menu 'recreate module'.
the pb is that in HH3 the recreate command, also erase settings of the module.
In the next major release I'll try to keep the setting after a recreate.
