Hi. ndi seems to be a new protocol very often used to stream video.
The sdk is free and implemented on all the new video media servers systems (resolume, millumin...)
here
is the link for the sdk.
It would be cool to see it on usinne HH !
newtek ndi
what are the applications of this protocol ? Is it like syphon ?
it allows detect ip camera as a device. a little bit like video flow player but without any config and with a very low latency
An Audio ip flow player would be very usefull to !
NDI is a technology developed by Newtek for multiple simoultaneous streams and video broadcast using a single Gigabit Ethernet network.
I saw a side by side comparation of a video with timecode showing frame counter and a NDI streamed video and don't found visible diferences.
With a NDI video output we are allowed to process all the video on one PC, put the stream on a wired network and receive it on other PC at a long distance using low cost CAT6 cable with virtually no latency.
I think that isn't hard to create a module of NDI streamer to be added to Usine HH3, but I don't have experience with HH SDK or NDI SDK, and I don't have enough experience programing on C++.
Do you know somebody that can develop this module?
I need it to connect HH with Watchout.
