export midi learn map and preset content
joffo78
Unread post by joffo78 » 13 May 2018, 11:08
Hello.
I know it's difficult because it seems to be very contextuel. But I't would be usefull if we can
export presets as file of a preset manager and all the learn of a workspace (which is already visible on a list) .
Unread post by senso » 13 May 2018, 11:23
yes, presets (or learns) are linked to target objects. Objects have an Unique-ID and a preset/learn is associated to this UID.
Loading a preset/learn without the associated object (UID) is useless.
Not sure to be able to find a soluce, but I'll think about.
joffo78
Unread post by joffo78 » 13 May 2018, 12:44
Je me doutais que c'était un truc dans ce genre :)
