'Directory' option for file lister module's file type setting
Unread post by woodslanding » 18 Dec 2017, 05:58
There doesn't seem to be any straighforward way to get a list of subfolders in a directory, but it seems like it might be easy to add it to the list of file lister file types???
I tried searching for files that have no extension (a workaround from the pascal forums) but the file lister seems to ignore subfolders entirely..... and all the pascal file manipulation stuff I've found doesn't seem to work within the HH scripting environment.
happy holidays!
-eric
Unread post by senso » 31 Dec 2017, 18:21
ok, done in the v155
Also with a search option: top directory only, all directories
Unread post by woodslanding » 01 Jan 2018, 10:08
SWEET!
