auto-scale down size of the patch if it doesn't fit in rack
x.iso
Unread post by x.iso » 11 Nov 2017, 20:12
I've noticed that if you use grid or just have Usine in windowed mode, if some patch is big enough to displace all other patches in the way, it then stretches the rack beyond scroll bar and part of it becomes inaccessible. This could be solved with automatic scale down once patch hits both the ceiling and the bottom of the rack (kinda squeezing the patch in process), then when you close the grid or make it smaller, patch could automatically restore towards original size as vertical space becomes bigger.
Unread post by senso » 11 Nov 2017, 20:50
please send bug report instead of the forum.
It's easier for us.
x.iso
Unread post by x.iso » 11 Nov 2017, 22:48
I usually do, but this is just a feature suggestion, no? Or was it supposed to work as I described?
Unread post by senso » 29 Dec 2017, 18:48
ok, I understand now.
It's not so easy to make it automatic. I'll think about it, and try if I can find something.
