custom knobs/sliders/etc
goyya76
Unread post by goyya76 » 27 Feb 2008, 14:10
the title says it all - will it be possible in the future? just out of curiosity, i recognize it's not a priority! (but there are very nice "BCR like" knobs made by Kvr member asseca....)
Ciao,
Goyya
Unread post by senso » 27 Feb 2008, 15:10
I'll work with nay seven, on the skinable version of Usine, after the finished the VST one...
Not only for knobs but for all designed parts of the soft.
Unread post by nay-seven » 27 Feb 2008, 17:55
by the way , have you tried my patch for your REV2496...( nrpn post )....?
Unread post by senso » 27 Feb 2008, 19:11
Sorry not really tested yet... but the noticed bug is fixed!
Unread post by nay-seven » 27 Feb 2008, 19:30
thanks senso , but was first for goyya76 , exept if you have also a rev2496....;-))
goyya76
Unread post by goyya76 » 29 Feb 2008, 15:51
nay-seven wrote:thanks senso , but was first for goyya76 , exept if you have also a rev2496....;-))
hi nay-seven....i check this forum twice a day, but i missed your post with the patch! sorry - however i downloaded and tried it yesterday - i see it creates CC 98, 99 and 6 - the REV2496 receive LED blinks,but the unit does not react - i guess we should create CC 38, to have 14 bit NRPNs, which can be recognized by the unit! i'm gonna try that later...
Ciao,
Goyya
