Patch Edit - Zoom!
I know this is probably far off...but you know whenever I patch depending on my resolution as well...it's hard for me to see and wire nodes.
It would be totally cool to be able to zoom the patch edit/module window just like a user interface zoom!
-s
-s
agree
in big 'towns' zooming out could help too
+1!
Also click and drag to select multiple modules or wires. even better: shift+click and drag to select modules and ctrl+click and drag to select wires.
For info, Shift+ click and drag to select multiple modules is already implemented
oh wow, I thought I already did try it. there's nothing about it in the corresponding manual section. is there perhaps a separate section with all those contextual shift-click and similar actions?
ok, zoom will be available in the patch editor.
v 3.0.145
v 3.0.145
Users browsing this forum: No registered users and 28 guests
