Wire Disconnect
sephult
Unread post by sephult » 13 Oct 2017, 18:52
I was thinking it would be cool to have a wire disconnect method.
At the current time you have to select or delete the wire by finding the center point etc.
Now if there could be a hotkey, then click the node it would highlight the wire.
If multiple wires just click again to toggle to the next.
This way if you can stay centrally located at where you are patching instead of having to backtrack or trace down
another wire.
-s
Unread post by 23fx23 » 13 Oct 2017, 19:46
A method i like in another nodal i use for vfx, is when pressing y (but could be different) it enters the 'cut' mode, and mouse act then as a cutter, just 'drawing' accross wires, that make it really easy and fast to cut several wires (also kinda trippy^^). or when taking a node and shaking it fast it disconnect all pins
x.iso
Unread post by x.iso » 13 Oct 2017, 23:25
It's not just about making it easier for user. When wire is connected between input and output of same patch/module, you can no longer select the wire by it's center and can't disconnect it either.
sephult
Unread post by sephult » 14 Oct 2017, 04:53
hahaha well then why don't you stop doing that x.iso....it's a trap! lol
I know Ive done that many times....thru I keep telling myself...use a thru. :lol:
-s
Unread post by SylvainT » 14 Oct 2017, 09:38
+1 for the cutter method :)
Unread post by 23fx23 » 14 Oct 2017, 11:58
x.iso i agree but yeah lets admit its rare case^^, the trick in such case is to re create same connection, it will remove the wire
Unread post by senso » 28 Oct 2017, 20:11
I'll think about all of that an try to find a way to delete wire more easily.
Users browsing this forum: No registered users and 112 guests
