Reset drop file name trigger
ahonoe
Unread post by ahonoe » 30 Sep 2017, 23:03
I am using drop filename for my UI interactions. It would be super useful to have a "reset drop file name" input on all objects that support drop file names. I imagine this working like the "clear" trigger currently does on list objects.
Thanks.
Regards,
Scott
sephult
Unread post by sephult » 04 Oct 2017, 11:12
+1
Unread post by senso » 21 Oct 2017, 17:37
You already can clear the field with a [ctrl+click] but I can add a reset button.
will be implemented in 3.0.144
sephult
Unread post by sephult » 21 Oct 2017, 17:51
Will this be an exposed node for the reset button?
So you can wire in and reset from an external source?
-s
Unread post by senso » 21 Oct 2017, 17:53
yes, an inlet to reset it from an external source
Users browsing this forum: Google [Bot] and 24 guests
