Joy Learn?
sephult
Unread post by sephult » 24 Jul 2017, 04:23
Having soo much fun with a Logitech Extreme Pro Flight Joystick and Usine!
But man it was a disappointment when I was going to setup the 6-base buttons to change presets....and...umm.... I realized it was not a MIDI or Keyboard Learn...bummer.
Maybe a Joystick Learn could also be in the future plans?
-s
Unread post by senso » 20 Sep 2017, 12:44
not sure, as the joystick is not a 'device' but a simple module.
also it's probably hard to press the main button without moving the YX axis ?
or move the X without moving the Y ?
So in many cases a joystick learn will be useless.
Did you try the BINDS concept in Usine ? it does a better job in this case.
see video tuto's
sephult
Unread post by sephult » 20 Sep 2017, 13:09
Awesome thanks for the suggestion Senso,
I will take a look at the BINDS.
-s
