Multiple simultaneous wiring per objects selected.
La Tenaille
you can hold ctrl+shift while dragging.
dmitriyc
Hmm...doesn't seem to work for me. I tried all combo buttons... is this an option to turn off or on somewhere? Just to clarify, Im recommending that if you shift+select modules and drag out a wire, multiple wires would come out of the selected modules simultaneously so I don't have to mess around with the position of the modules just to figure out if all patches have connected to a single point or not.
La Tenaille
I don't think this function can be deactivated. I hold ctrl+shift and drag from a module pin to another and multiple wires are created. I don't know the limitations of this shortcut but to link let's say 8 audio audio matrix module out to 8 audio matrix audio in it works and creates 8 wires.
