Global Header Patch
sephult
Unread post by sephult » 14 Dec 2016, 11:06
I was thinking there should be some sort of Global patch that can be referenced from other patches.
At the moment you have to create a rack or use IB in order to do this.
If a global header patch(where synchro exists) is available then custom buttons, displays, etc...could be made and referenced from multiple patches/racks.
More like a overall workspace or control patch.
-s
Unread post by senso » 21 Dec 2016, 17:21
I think you should wait for the future script engine. be patient.
sephult
Unread post by sephult » 22 Dec 2016, 02:15
I know :)
Ideas just won't stop, and the excitement either!
I will be patient...just excited.
-s
