The grid : type and set points/curves values
Unread post by rlgsbt » 28 May 2016, 14:48
it would be nice to type points/curves values directly in the grid and set the points on the time grid. Cause it's moving when you add or change sections.
By the way, I watched screen capture by Hervé Birolini and HH3 looks great...
Unread post by senso » 09 Sep 2016, 08:57
I'm not sure to understand.
Can you explain a little more ?
thanks
Unread post by rlgsbt » 09 Sep 2016, 16:11
Lorsque l'on crée un point dans le grid, il faudrait pouvoir taper précisément la valeur et la position. Peut-être avec un double clic pour accéder à la valeur ?
merci
Unread post by SylvainT » 10 Sep 2016, 11:08
+1
good suggestion
Unread post by senso » 13 Sep 2016, 08:15
un double click c'est pour créer ou effacer les points...
je vais réfléchir à la question.
Unread post by rlgsbt » 13 Sep 2016, 11:48
merci Senso
Unread post by oli_lab » 13 Sep 2016, 23:27
in Reaper you do shift + click, very cosy !
La Tenaille
Unread post by La Tenaille » 15 Sep 2016, 11:48
alt-clic to match the text edit shortcut ;-)
Users browsing this forum: Bing [Bot] and 3 guests
