Suggestions
franck
Unread post by franck » 04 Dec 2007, 15:44
Hello Olivier
I have 2 suggestions
1 / Add more funtions to the "Panic" button, ( Clear alls audio buffers, send all notes off).
2/ Another option in settings : for sequencer mode (during playing) when you move the cursor in new time line position, sometimes there is "loop noises" (audio buffers playing before move cursor are not empty). A solution is to validate an new option when you move cursor during Usine is playing: to stop automaticaly the playing, clearing all audio buffers, send all notes off, and plays again at the new cursor position. I know this is not an ideal option for Live use but at home.....
What about that ?
thanks
franck
Unread post by senso » 04 Dec 2007, 18:33
I'll study your suggestions.
But clearing all audio buffers is not so easy...
I'll try to find something.
franck
Unread post by franck » 05 Dec 2007, 09:21
Hello Olivier,
for my suggestion number 2 is it not possible to stop the sequencer (like i press stop in dashboard) when I move cursor during sequencer is playing and after a litle time, play again automaticaly the sequencer. When I do that manualy there is no " loop noises". It willl be an option in seetings windows because I think some users dont like this option.
Franck
