I would like to thank senso and the team for this beautiful software. However, there is an issue that has not been addressed yet.
In usine v5 when modulating a vst parameter using the parameter array available on each vst, the modulations were instantaneous. Unfortunately in HH this is no longer the case. No matter when using the parameter pins or through the array, parameter updates happen only between a low resolution boundary (bloc?, refresh rate?). I mentioned this a long time ago and the option for instantaneous access to vst parameters was promised but it was never implemented. In its current form, it is impossible to modulate parameters with precise timing resolution. Could this possibly be solved in HH2?
Thank you for your support.
problematic vst parameter resolution
I noticed the announcement for HH2 and it looks amazing. Would it be possible to include the above suggestion as an option in the next release? Perhaps a checkbox in the global setup ("allow direct VST parameter modulation"...use at own risk") The reason this is so important is because when triggering a VST with a MIDI message, the modulation does not always arrive on time before the note is received. Using a "wait one bloc" between the note trigger does not solve it either. Looking forward to your response.
in HH2 the "all parameters" array input will have an instantaneous effect.
senso+++
senso+++
this is great news! thank you for taking the time to address this. your efforts are appreciated.
Users browsing this forum: No registered users and 47 guests
