midi learn option: 'global' or 'saved in preset'
CREDO
Unread post by CREDO » 27 Oct 2014, 18:43
Maybe it's too complicated to implement... but with a limited number of control sources, a simple way to 'bind' them dynamically would be a HUGE help :)
Unread post by senso » 21 Nov 2014, 13:41
it could be implemented easily in usine but all control modules will have 20 more inlets and will increase the memory allocation for very specific problem.
Finally I'll take a compromise, only export the following inlets
midi learn
mode
channel
control type
control num
smpte
time code
osc learn
osc message
binds
binding string
