It would be realy powerful if the sampler could remember some settings for each file. Like loop in and outpoint, markers, transpose, speed. And maybe an array that could be used to store some parameters such as gain, pan, or other values that could be recalled on other modules.
Guillaume Thibert
Sampler to remember files settings
Guillaume Thibert
www.cemproduction.com
It's easy to do that with a preset manager isn't it ?
Could be, but not as intuitive and useful as what i think about.
What I propose is a bit like in Ableton Live, where you can set gain, transpose, loop points, etc on the sample. If you open this sample in another set, everything is recalled.
So simply changing the file in the sampler list could change the settings, and it could be realy poweful and intuitive. Currenty, I have to edit every audio files to match volumes and to get a perfect trimming, so when I play live, I'm sure that when I drag a file in the sampler everyting is set.
It could be powerful to save other parameters. I do a lot of surround work and it could be nice to be able to recall, let's say, an audio matrix settings array for each sample. Or an FX send setting, Or pan. Or automation curves. Or anthing.
It could be stored in a hidden file, like wavesforms are stored in xxxx.usine.peak. Like Ableton does...
I does'nt seem too complicated from a programmer point of view, and a pretty basic function that would unleash possibilities.
For me, it's one of the drawbacks of Usine. I could pay for this improvement.
Guillaume Thibert
Hard to implement but I'll think about it.
this what I'm doing rigth now with the help of some scripts...
see my post :
http://www.sensomusic.org/forums/viewtopic.php?id=4586
for the markers, i'm planning to save a text file containing the markers array afeter having converted it to comma text.
see my post :
