oscillator module suggestions
soundmind
Unread post by soundmind » 11 Dec 2013, 23:31
The oscillator module is a very useful addition the usine but it is lacking some key features.
1) ability to reset the phase of the wave to a specified position.
2) an input pin to set the wave shape from the control panel.
3) This one may be far fetched but how about the ability to accept an array as a user defined waveform?
any of this possible?
Unread post by senso » 06 Feb 2014, 13:26
thanks for feedbacks
1) implemented in the next release (1.1) as 'init phase button' and 'init phase value'
2) don't forget that you can expand modules to display more inlets...
3) maybe later, the osc is made very simple
Unread post by oli_lab » 31 Mar 2014, 14:13
Indeed this little oscillator module is quite capable and fun.
I did some experiment with FM and was amazed that audio signals can be happily routed in the frequency an amplitude inputs (or is it a misuse ?)
[s]Now it could be very cool to have saw tooth wave form as well[/s]
also I made an audio rectifier with the abs(x) module, is it ok ?
try sync one osc with another one (in audio mode) but no success
Unread post by senso » 06 Apr 2014, 09:52
the oscillator is very basic in HH and not really suitable for pro synthesis.
they are many free synth (vst) which can do the trick?
