SubRacks
CREDO
Unread post by CREDO » 20 Aug 2013, 00:05
I realise this may seem redundant at first, but I think it would be great to be able to add/reorder/deactivate patches within a single patch the same way as in a rack.
Context:
I mostly use Usine for complex effects presets, and this would cut down on the number of racks otherwise necessary, and allow for special "container" racks able to hold many effects chain options, both quick to switch between and much simpler to create and modify than traditional SubPatches.
trik
Unread post by trik » 20 Aug 2013, 10:09
When you use the Interface Builder you can always show/hide subpatches with a switch.
CREDO
Unread post by CREDO » 20 Aug 2013, 18:41
True, but a more "rack like" structure would just be a lot simpler than building an interface for each plugin combination, especially when working with more straightforward vst fx chains.
Unread post by senso » 03 Sep 2013, 09:24
1) I'm not sure that it's good to add another patching layer like that. Usine is complex enough?
2) if you consider multi-channel patching it's very hard to implement and probably very hard to use?
