mmm... mmm... DXI ?
stanlea
Unread post by stanlea » 16 Aug 2007, 00:45
Would it be difficult to wrap DXI effects or instruments in Usine ?
Pas taper... :)
You know my name (look up the number)
Unread post by senso » 16 Aug 2007, 18:45
I don't know!
Probably not so easy.
Is ther any good DX-->VST wraper?
stanlea
Unread post by stanlea » 16 Aug 2007, 19:20
The only one that I found is Console, which is in fact an modular host, no so sophisticated as Usine. It can be load as vst effect or instrument.
http://console.jp/en/
franck
Unread post by franck » 16 Aug 2007, 21:00
Try here
franck
stanlea
Unread post by stanlea » 16 Aug 2007, 21:52
Vincent
Unread post by Vincent » 17 Aug 2007, 00:24
Hi Stanlea.
Console
I did not remember that Console could be a VST.
Do you really mean that you can plug it in Usine?
...And plug DXI VSTs in Console?
So... What about DXI in Console and Console in Usine?
vincent michel
composer & novelist
stanlea
Unread post by stanlea » 17 Aug 2007, 00:26
Yes sir, it works ! I can play some DXI synths in Usine with Console. Download the demo and try by yourself, it's amazing. I have some interesting DXI things that I had when I bought Sonar Home Studio, now I can use them anywhere.
Vincent
Unread post by Vincent » 17 Aug 2007, 00:53
My synth (Moog Modular, Absynth, Reaktor) work either in DXI/rtas/VST, so I did not try the DXI setup. What exactly is the difference?
Console was nice, but I met Usine almost in the same time and made my choice... Sometimes it crashed. I don't really like the idea of a crashing soft when I'm on stage... But it was nice.
vincent michel
composer & novelist
stanlea
Unread post by stanlea » 17 Aug 2007, 01:03
In fact, it's useful when you want to use something which is DXI only. The interest of Console is that it loads DXI besides VSTs. Maybe very few people need to do such a thing.
franck
Unread post by franck » 17 Aug 2007, 11:22
Excuse me Stanlea , here is the link for a free wrapper for DX - VST (FFX 4 is a free version) , it is OK for DX effects (I use it) but I dont know for DXI.
good luck
franck
http://perso.orange.fr/vb-audio/us/prod ... dxrack.htm
stanlea
Unread post by stanlea » 17 Aug 2007, 12:01
Thanks, I'll try it ASAP.
Actually, I can only load effects, but I have send a message to the support, wait and see...
stanlea
Unread post by stanlea » 17 Aug 2007, 15:31
Message received. Only effects, so at this time, I stay with Console, but I don't know if it's worth buying it... almost the same price as Usine, not so powerful. Maybe the trial version, without saving would be enough for me, if I manage well my presets. For the effects, I can use Vincent burrell's rack.
Vincent
Unread post by Vincent » 19 Aug 2007, 23:29
Hem, hem, hem... what is that
stanlea wrote:...Vincent Burrell's rack.
sounds interesting...
Maybe a small link?
vincent michel
composer & novelist
stanlea
Unread post by stanlea » 20 Aug 2007, 19:58
See Franck's message...
Users browsing this forum: No registered users and 94 guests
