Bypass switch for audio modules
bmoussay
Unread post by bmoussay » 26 Jul 2007, 20:38
Hello Usiners,
Just a small suggestion:
would it be possible for the filter, delay, and volume audio modules to have a switch (and an inlet) for bypass.
I know it easy to build with a small amount of existing modules, but I think it would be really practical to have it implemented in the modules themselves.
What do you think?
Best regards,
B.
Unread post by senso » 26 Jul 2007, 21:22
hello
Good suggestion. Can be turned into "Dry/wet" fader.
But it's so easy to create a sub-patch to do that... and so hard to implement it directly in Usine...
Also this function will probably increase the CPU load for in most circumstances, and add a tiny improvement for particular applications.
So I'm not sure...
bmoussay
Unread post by bmoussay » 30 Jul 2007, 02:01
Just to say that I've posted a series of subpatches containing audio modules with a dry-wet fader.
Rgds,
B.
