a time fade individually on each control
joffo78
Unread post by joffo78 » 27 Apr 2012, 15:18
It would be great if we could specify for each control (fader knob start and end position...) there own fade time when i recall a
conductor or preset memory.
we could imagine a specific variable on inlet of there modules !
:D
fisto
Unread post by fisto » 27 Apr 2012, 16:50
oh yeah, good idea man :D
joffo78
Unread post by joffo78 » 27 Apr 2012, 22:30
Yeah. I've got another suggestion about conductor. But seems to be more difficult to do.
First we could imagine to keep a global fade time in the conductor. And for example if the individual time of an object is 0 so it'll take
the global fade time as reference. and if the time of the object become bigger than 0 i keep is own time.
The second thing is that i could navigate on my conductor memories whitout recall them.
it means that when i navigate between my memories i could have a representaion of the settings content and modify some elements
but whitout changing the restitution.
It seems to be a little hard to do because how can i display a setting without calculate it ?
joffo78
Unread post by joffo78 » 28 Apr 2012, 15:16
here there is a little picture to illustrate my idea :Image
Unread post by SylvainT » 29 Apr 2012, 21:34
+1
fade time enable/disable for preset and conductor on faders and knobs would be a really good option
joffo78
Unread post by joffo78 » 29 Apr 2012, 22:00
I don't think enable/disable is enough. I prefer exclusive time fade one each fader and knob.
