Hi - one bit of praise and a suggestion for the new version. First, thanks for the improvements in the beta that came from my suggestions/wishes! I love the fact that the community is such that we can make these suggestions, and that Senso is dedicated to making them happen (and so quickly!). I have personally benefited from the multi-key learn and the new MIDI patchbay. Thanks!
One small suggestion for the multi-key learn (if you remember, I'm using it with the Griffin PowerMate, but I suspect others just using keys might benefit from this as well): when you reach the end (going either up or down), the value wraps (eg, in a range from 0 to 12, hitting 12 and then the "up" key wraps the value to 0). Is that intended/do people find that useful? If so, not a problem, but if not, I would love to see it stop when it gets to either extreme (so I can set a range, and spin the knob without having to worry about going over).
Anyway, thanks again for all your work on this - it's appreciated!
Steve
V2.85beta Report
a440
Steve [ http://www.a440.org/steve/ ]
Novation X-Station 25 (ASIO/MIDI i/f)/CME UF7/M-Audio Axiom 25/Korg Karma
- senso
hello Steve,
I think you are right. Now with the increase/decrease key learn, the actual function has no sens.
I'll apply your suggestion, normally it should be easy...
