another little suggestion::)
a fader, either vertical or horizontal but with the option to increase the value from the top to the botton and from right to left, that is, the inverse of the way it actually is.
I'm aware that is relatively easy to crossfade the values but that way is imposible to show the correct value inside the fader itself.
inverse fader?
waiting for this, a little tips ( disable show value in the layout ) :
good tip
