About interactivity
groolot
Unread post by groolot » 23 Mar 2006, 11:48
Will you add "right click" on Usine?
Gr?gory DAVID 'aka' groolot
http://www.groolot.net/
Unread post by senso » 22 Apr 2006, 11:05
I'm currently working on this subject. I try to keep Usine as simple as possible. I hope it will arrive soon.
groolot
Unread post by groolot » 22 Apr 2006, 13:07
What do you think about adding a more efficient way to disconnect a link between modules.
Because, if you want to disconnect a modules you have to ... do what ? Delete the module and then re-create it with new links ?
Unread post by senso » 22 Apr 2006, 18:46
The actual way is simple but sometime heavy...
The best thing should be to select one (or more links with the shift key for example) and move it.
I'll try to add this functionality soon.
